And it seems that i found bug. Toolbar button "Toggles the folder tree display (ALT+T)" doesn't work correctly.
Shortcut is ok, but toolbar button - not. Try to press it multiple times. Panel shows up, but don't hiding after second press.
spacedrone808
Re: Toolbar button "Toggles the folder tree display (ALT+T)"
can't confirm FCXE 744
spacedrone808
I' ve got the same issue on two different machines. OS: Windows 7 SP1 x64.alf5000 wrote:can't confirm FCXE 744
Commander is 64bit also..
Can't confirm in 744 64 bit.
How to report a bug (Read before posting!)
• Make sure you use the latest version of FreeCommander XE (if possible).
• Report the FreeCommander version and operating system. E.g. "FreeCommander XE 2014 Build 650 donor, Windows 7 SP1 64-bit".
• Try to reproduce a bug with default settings and without plugins. To do this use these command line parameters (your old setting files will be preserved):
/N /NewIni=FreeCommanderTest.ini /NoPlugins /Lng=English
Not confirmed for FreeCommander XE 2017 Build 744 64-bit donorspacedrone808 wrote:And it seems that i found bug. Toolbar button "Toggles the folder tree display (ALT+T)" doesn't work correctly.
The button always works
Windows 11 Home, Version 25H2 (OS Build 26200.8875)
Everything Version 1.5.0.1418b (x64), Everything Toolbar 2.4.1, Listary Pro 7.0.0.5 beta
FreeCommander XE 2026 Build 951 64-bit donor
spacedrone808
I am specific person with special karma, the bug was only in my personal configuration only.Thanks goes out to author of the program, which fixed it for me!
Users browsing this forum: No registered users and 102 guests
