FC donor 736-741 moving folders with teracopy3rc2
peter_altherr
#1 Post by peter_altherr » 10.01.2017, 16:47
i am using FC donor x64 together with teracopy3rc2 for file/folder copy/move actions and everything works as expected but one thing always makes teracopy dropping an error message. whenever i try to move a folder the operation completes (successfully) but afterwards teracopy is always claiming:
Teracopy - Error
Unable to access:
<drive and path to the orginal location of the moved folder>
the detailed teracopy log tells this:
error opening source file: the system cannot find the specified file. code: 2
at first i thought about teracopy3rc is causing the error message because it is still a release candidate no stable version but then i tried all the file/operations with teracopy using windows explorer and everything goes well and smooth. i have teracopy integrated in FC like this (hoping this is the correct way):
in settings menue i choose external program for copy and move and put this in the line below:
C:\Program Files\TeraCopy\TeraCopy.exe copy *%ActivSelAsFile% %InactivDir%
C:\Program Files\TeraCopy\TeraCopy.exe move *%ActivSelAsFile% %InactivDir%
i use the installed x64 version of teracopy not the portable one.
anybody any clue about this or maybe the same observation when moving folders with teracopy?
thanks
peter
edit: fc/teracopy versions updated
peter_altherr
Re: FC donor 736-741 moving folders with teracopy3rc2
#2 Post by peter_altherr » 06.02.2017, 15:57
hmm, more than 80 hits on this topic but no reply. i wonder if i am the only one suffering this problem...
peter_altherr
#3 Post by peter_altherr » 06.02.2017, 20:06
by random i found out today the problem only occurs when i try to move folders on the same drive. it does not occur when i move folders from i.e. drive c to d but from c to c or d to d.
Fad
#4 Post by Fad » 05.08.2017, 09:57
I am also having this problem [when copying folders on the same drive]
It only happens with TeraCopy v3.x NOT with v2.x
Users browsing this forum: Bing [Bot] and 11 guests
