The setting for Config File was "Specific for user - "Application Data" folder
Vista 32 SP1.
Upgraded from R352.
Each time freeCommander R352 started, it's using user specific "Application Data" folder - in my case
C:\Users\Jeff\AppData\Roaming\freeCommander\FreeCommander.ini
After R355 installed, upon first time starting freeCommander, it defaults back to the install folder.
After change the setting, freeCommander picks up the correct settings.
Best Regards,
Jeff
R355 - Settings - Start Program - Config File
To reproduce, first, we need to confirm that you are using user specific settings:
1. Make sure you have previously selected "Specific for user" under Settings/Start Program - it allows FC to create the INI file (freeCommander.ini) in C:\Users\user_id\AppData\Roaming\freeCommander folder.
2. After choose "Specific for user", make some visual change - i.e. Size, Location, open Tabs, etc.
3. Exit FreeCommander to save the change or select Extra/Save Settings.
4. Restart FreeCommander to confirm the change is saved.
To reproduce,
1. Re-install FreeCommander.
2. Start FreeCommander - you should see that it is NOT using your 'user specific' settings.
3. Change the option, and restart FreeCommander.
4. You should now see the user specific settings.
Regards,
Jeff
To reproduce,
Regards,
Jeff
Users browsing this forum: No registered users and 11 guests
