Set colors to folders
giudansky
#1 Post by giudansky » 15.04.2026, 17:29
Pleeeese do you think it could be possible to custom colorize folder rows ?
Yeees I know I can do it by timestamp and type but I really need a quick way to colorize some folders on the fly, not by any specific attribute.
Would this feature be possible, ever ?
Re: Set colors to folders
#2 Post by Marek » 16.04.2026, 20:15
How many folders should have their own color? Is it, for example, 200, 2000, 20000?
giudansky
#3 Post by giudansky » 21.04.2026, 10:55
I know what color folder means: a database and a performance issue.
The reasonable answer is: 400 ? It's a way to temporarely emphatize folder workflows. So there is no need for giant colors database.
But now, figuring out a solution, I'm thinking about another way:
What if the coloring is assigned in reaction to a specific customizable string? It could be an expansion of the actual coloring functions based on folder names.
For example freecommander could assign a custom color if the folder contains the strings "photos" "or "note" or "archive" whatever... so the folders "my photos", "client archive", "log notes" will inherit the custom color
What do you think ?
Thanks for listening
#4 Post by Dreamer » 22.04.2026, 21:46
The other idea could be similar to "Color by file type" for files.
giudansky
#5 Post by giudansky » 23.04.2026, 10:01
Exactly, an extended rule which recognize specific strings in files/folders. In that way I can set a rule of strings and using the appropriate names to obtain the color (and possibly the icon :D )
#6 Post by Marek » 30.04.2026, 14:30
You can define color for folders under "Settings->File/folder list: Color by file type".
With the "+" button you can specify filter for folder path or filter for folder name.
giudansky
#7 Post by giudansky » 04.05.2026, 13:25
you did it!
Users browsing this forum: No registered users and 8 guests
