Search in archives not working
Posted: 30.12.2019, 23:06
by dezkohorvath
FreeCommander - nice GUI. After "Total Commander" the nicest.
In archive C:\dir1\dir2\test1.zip I have file abc.txt
In File->Search
File name: abc
Search File content: Empty, I did not use it.
Folders: C:\dir1\dir2
Search in subfolders up to level: 0 (no-limit)
Search in archives: Yes (checked)
File abc.txt is not in the "Search result" list.
When using "Total Commander" or "Double Commander", the "Search result" will show in the "Search result": "C:\dir1\dir2\test1.zip/abc.txt"
Thank you, happy new year.
Re: Search in archives not working
Posted: 31.12.2019, 00:06
Which version are you using? If you're not already using it, upgrade to XE 2019 Build 804 32-bit public beta, it's stable.
Can't confirm in 804 public / 808 donor.
Posted: 31.12.2019, 03:41
by dezkohorvath
Thank you, FreeCommander in version "804 public beta" can find the file "abc.txt" from the previous example.
Still the problem persists with searching directories / folders:
Files + directories in archive C:\dir1\dir2\test1.zip:
abc.txt
dira\dirb\xyz.txt
In File->Search
File name: dirb
Directory "dirb" is not in the "Search result" list.
When using "Total Commander" or "Double Commander", the "Search result" will show in the "Search result": "C:\dir1\dir2\test1.zip/dira\dirb"
Thank you
Posted: 31.12.2019, 15:27
OK, folders in zip archive are not found, confirmed.
Files in zip archive placed in archive subfolders are found with my settings, but not found with default settings, strange.
Posted: 01.01.2020, 00:12
by Odamn-Ete
Dreamer wrote: 31.12.2019, 15:27
+1
FreeCommander XE 2019 Build 808 64-bit donor
Windows 10 Pro 64-bit Version 1909 Build 18363.535
