Document List Panel display sort options
Posted: 07.01.2020, 12:17
by markpokane
When I start Freecommander XE, the Document List Panel contents are sorted in a fashion I cannot determine (see attachment) and I have to click on the "Name" column to get them sorted.. There should be a configuration capability to list them:
1. Alphabetically
2. Oldest first
3. Newest First
(57.26 KiB) Downloaded 469 times
Re: Document List Panel display sort options
Posted: 07.01.2020, 22:02
If you do not use the current program version - update first https://freecommander.com/en/downloads/.
Nothing can be seen on your screenshot:
- other columns
- columns heder
- full path in address bar
