Enter to open
Posted: 16.07.2008, 03:32
When highlighting multiple files under Explorer, you can then press Enter to open them all at the same time
In FC, it is always the file that has focus that is opened when Enter is pressed and not the highlighted ones.
I have found that if you highlight the files you want to open then right click a highlighted white space and select Open, this does work. The only issue is that Enter does not know about the other highlighted files.
