Icon for locked tab??
Posted: 20.02.2020, 12:19
by mgroen
Been busy on the locked tabs this morning.
I noticed on my machine the icon fo a locked tab is different as described in the Help. Not sure about this:
- Right click on Folder bar (not sure if this name is correct) -> New Folder Tab. New folder tab is created (OK);
- Right click on the new folder tab -> Lock folder tab.
A "#" is placed in the new folder tab.
See here:
https://postimg.cc/YjJVQNdj
Not sure the Help file is mentioning the same symbol...
Re: Icon for locked tab??
Posted: 20.02.2020, 16:30
by ralfso
Settings > View > Folder Tabs > Tab Management > Mark locked tabs with that character
If this setting is checked, the character entered in this input field will appear in front of a locked tab's title to symbolize the lock.
https://freecommander.com/fchelpxe/en/T ... .html#mark
Posted: 21.02.2020, 12:36
by mgroen
ralfso wrote: 20.02.2020, 16:30 Settings > View > Folder Tabs > Tab Management > Mark locked tabs with that character
Clear. Thanks!
Posted: 27.02.2020, 20:42
Try out using this sign as marker
as it is clearly visible and yet takes little space- thus allows for more content to fit in your Tab Bars in one line [level]
Posted: 28.02.2020, 15:27
by mgroen
Posted: 24.10.2025, 09:46
Some development in the discussed above feature:
● optimal signs [icons]: viewtopic.php?t=14144
● proposition for expanding of capabilities: viewtopic.php?t=14143
