default location for output file
Posted: 23.02.2020, 21:32
by dbiando
I posted this question several years ago and got one answer that was not helpful, so I thought I would post again. Hopefully someone can help. I am looking for a way to change the default location of the output file when making a file list. As it stands now I have to manually change the target directory for the output file each time I make a list. The default is to create the output file in the same folder as the indexed files. However, I keep the lists on a drive different from the drive with the folders that has been indexed, and I make file lists of numerous folders. So manually changing the target each time I make a list is tedious. Any help would be greatly appreciated. Thanks!
Re: default location for output file
Posted: 23.02.2020, 22:16
I think it's not possible now, so I moved this topic to Feature Requests forum.
Perhaps something like in Rename dialog, drop down menu with last used paths could be added - or the Profiles tab as in Multi rename, with options to add custom paths, first path could be current path.
Workaround - you can create tab with the path you want to use, then click the copy path button in address bar - and paste in the "Make folder list" dialog.
Posted: 23.02.2020, 23:12
by dbiando
Thank you very much for the information and the moving of my post. Appreciated!
Posted: 24.02.2020, 22:42
In the next release 814 will be possible to define the default folder for the output file in the FreeCommander.prtf.ini file.
You can then define default folder for each profile.
Example:
[9AB1365B-6032-468A-95BB-4543FFA4B23A]
Name=Default_Profile (TAB getrennte Felder)
TargetFolderForOutput=c:\temp
The defined folder must exists.
The value of TargetFolderForOutput will be used as default value in dialog.
Posted: 25.02.2020, 00:34
by dbiando
Thank you for the information and thank you for great software. I look forward to the update!
