816 - In plain/flat view, cannot create Windows shortcuts via drag and drop
Posted: 12.04.2020, 09:30
FC 816 64-bit donor on Win7 64-bit
From files being displayed in plain/flat view, you cannot create Windows shortcuts via drag and drop to the other pane.
Tested with showing the pop-up menu for drag and drop.
