Show in r/h pane
Posted: 24.07.2008, 21:03
by bertie
I've just started using Free Commander but I can't see how to click on a drive or folder in left hand pane and see the details in right hand pane. This is how I used to use Powerdesk.
Is this possible>
Posted: 25.07.2008, 00:43
Do you mean "Quick view" (Ctrl+Q)?
Show in r/h pane
Posted: 25.07.2008, 09:16
by bertie
Hi. Well, not exactly. If I click on D:\ drive in the drive list for example, and do CTl+Q, all I get in the r/h pane is a total of files in a folder on the D;\ drive, but not a complete list of files and folders from the top of the drive tree which is what I want..
Or, if I select C:\in the drive list, then CTL+Q, all I get is the same thing, ie, total files, etc. but because the top folder in the l/h pane is highlighted (usually Recycle Bin) I get the precis of contents in the r/h pane of the Recycle Bin!.
Hope that makes sense!
Posted: 26.07.2008, 00:43
Hmm.. perhaps it would be clearer with the screenshot from the other program, to show what exactly do you want. If you don't know how to make a screenshot check this topic please:
http://forum.freecommander.com/viewtopic.php?p=28#28
