822+810a - Thumbnail tooltip issues with large font size
Posted: 13.06.2020, 16:20
- switch to thumbnails view
- in test folder create folders with the names like this:
2020-01-01 - AAA - Aaaaa A Aaaaa Aaaa
2020-01-01 - Aaaaaa - Aaaaa
2020-01-01 - Aaaaaa - Aaaaa A Aaaaa Aaaa
2020-01-01 - Aaaaaaaaaaa
Abcdefg
- in Settings > view > file/folder list > color/font - change font size to 12
- click the Apply button
- in Settings > view > thumbnails - set Spacing to X=10, Y=40
- click the OK button
- some folder names show the name only in 1 row
- filename "Abcdefg" is shown as "Abcdef", 1 character is missing, even if there is enough space
- move a cursor to folder with name "2020-01-01 - AAA - Aaaaa A Aaaaa Aaaa"
= tooltip it cut off
- move a cursor to folder with one row only, e.g.
= tooltip is not shown at all!
- click/focus the folder "2020-01-01 - AAA - Aaaaa A Aaaaa Aaaa"
- move a cursor to folder with name "2020-01-01 - AAA - Aaaaa A Aaaaa Aaaa" again
= tooltip is not shown at all, for any focused/selected folder or file in thumbnails view
* sometimes the tooltip for focused item is shown, then it's broken, I'm not sure when
EDIT: Tooltips are broken also in Details view, I'm trying to reproduce it...
EDIT2: I mean just the tooltips for items which are not fully shown, not the tooltips which can be enabled in Settings (Show files and folders tooltips).
I'm using 100% OS zoom, so no extra zoom, no special high DPI options for FC.exe.
FC 822 donor+810a 32-bit public, Windows 10 1909.
Re: 822+810a - Thumbnail tooltip issues with large font size
Posted: 19.10.2020, 22:00
Fixed in unknown version, it works in 831 donor 64-bit.
