822 - Folder Specific Column profiles seem not to work on Subfolders
Posted: 26.06.2020, 08:22
by Mr-Fly
Hi.
Discovered this today:
When using folder specific column profiles, they seem not to work on subfolders, although configured for them.
In my case I added the sizeondisk column to the Onedrive folder, but subfolders will not have the additional column anymore:
2020-06-26 08_12_40-Settings.png (10.92 KiB) Viewed 15374 times
2020-06-26 08_11_53-C__Users_xxx_OneDrive - - FreeCommander XE.png (5.51 KiB) Viewed 15374 times
2020-06-26 08_12_10-C__Users_xxx_OneDrive - _Dokumentationen - FreeComman.png
2020-06-26 08_12_10-C__Users_xxx_OneDrive - _Dokumentationen - FreeComman.png (5.38 KiB) Viewed 15374 times
Re: 822 - Folder Specific Column profiles seem not to work on Subfolders
Posted: 26.06.2020, 20:43
Do you have "*" at the end? Like "...\subfolder*".
Column profiles
Posted: 26.06.2020, 21:56
by Mr-Fly
I believe you should not have to.
I will try it, but the folder path was added by the dialog itself (save column view for this directory)
The masking is an addon feature as far as I understand it
Posted: 26.06.2020, 22:32
by Mr-Fly
Went again to my pc to check on it.
If I put it to the end of the last foldername, it will then work.
But this function:
2020-06-26 22_30_30-.png (1.61 KiB) Viewed 15340 times
Does not do it!
And in my eyes with the "subfolder" setting the "*" at the end should not be needed.
Posted: 26.06.2020, 22:37
by Mr-Fly
One example why it would be bad to force a * at the end:
C:\Temp\Folder1
C:\Temp\Folder1b
If I only want to set a specific rule to the first including subfolders I would not be able to as folder1b would also react. So there is a Good reason for the subfolders setting of FC in this case and it’s in my eyes a bug.
Posted: 30.06.2020, 09:58
by Mr-Fly
So is this now a bug or is it wrong usage?
Posted: 30.06.2020, 14:51
Try to use
<sub>c:\temp;c:\temp\*
Posted: 30.06.2020, 15:21
by Mr-Fly
Thats works.
But what I dont get is, the config dialog states "<sub>" which means subfolder.
With this aproach it feels more like <mask> direction of the config and not in the <sub>?
Additionally adding a folder with the gui will not do this
