Disable "wrap around" options in viewer
Posted: 04.08.2008, 23:53
1. When I want to check just few files in viewer, I press F3 and Space few times to check it, but "wrap around" option is always enabled and there is NO indicator after the last file. This is very annoying.
2. When searching in viewer and the page end is reached, only the small icon is show and the search is started from the page beginning. Usually I just want to search the word once and I must always watch also the status bar now. It's very annoying too.
My suggestions:
A) Add options to disable both wrap around options.
B) Or/and add a dialog box when the search is started from the beginning - and after the last file is reached in viewer.
Thanks.
