Diffrent sorting for diffrent folder
Posted: 04.09.2020, 07:38
by Havall
Hello everyone.
I've been looking fo feature that does this :
I want to have have different sorting for diffrent folder at the same time.
==> Let say I want the folder A to sort item by name, but another folder like B I want to sort item by date.
Is it possible to save the sorting preference by folder so I don't have to change it everytime ?
Thanks in advance :)
Re: Diffrent sorting for diffrent folder
Posted: 04.09.2020, 08:38
You cannot set the sorting for every folder, but for some folders that you use frequently.
Please check favorite folders.
Another possibility is using of the automatic views.
Posted: 04.09.2020, 08:56
by Havall
The trick with favorite folder help a lot !
Thank you very much.
Posted: 19.12.2020, 16:33
by fjelsten
I think if the current functionality would be expanded so that just entering the folder would activate sorting and display, then it would be great
