829 - Spacer bars in status bar look bad
Posted: 19.09.2020, 15:47
Spacer bars in status bars looks bad - on left, could you use the color for lines - on right, please?
If not possible, perhaps the status bar text color.
Screenshots are from Dark grey default and Very dark color schemes.
FCSpacer bars in status bar look bad.png (22.32 KiB) Viewed 14291 times
FC 829 64-bit donor, Windows 10 2004 64-bit.
