831+830 - USB flash drive on Desktop issue
Posted: 22.10.2020, 23:02
USB flash drive is on Desktop (0) - it has no link on desktop, it should not be on desktop, in Explorer it's not on desktop item.
It's also on This PC item, it should be just here, with the other disks.
FC 831 donor 64-bit + 830 public beta 32-bit, Windows 10 64-bit 2004.
Re: 831+830 - USB flash drive on Desktop issue
Posted: 27.10.2020, 21:31
by Odamn-Ete
confirmed, showing everything on my desktop and additionally
this PC (two of them)
DVD Drive
external usb drive
Network
FreeCommander XE 2020 Build 831 64-bit donor
Windows 10 Pro 64-bit Version 1909 Build 18363.1171
Posted: 28.10.2020, 11:46
Go to Windows Explorer and in the address bar type Deskop and then press Enter.
Now you can see the Desktop - compare it with FC Desktop.
Posted: 28.10.2020, 21:57
OK, in Explorer there are 2 Desktop items, 1 of them is the same as in FC, so it's not a bug / at least not a FC bug.
Just Control panel is 2x in FC, but I think similar bug was reported already.
