Color schema for Windows 10 dark mode
Posted: 28.10.2020, 13:54
by mistromel97
I would like to have FC display contents like Windows 10 Dark mode.
Is FC able to do this? Is there a color scheme that resembles / imitates Windows 10 dark mode?
Thanks.
Re: Color schema for Windows 10 dark mode
Posted: 28.10.2020, 21:39
Microsoft changes the colors in Windows Explorer often, so it could be the same, if the FC could detect the colors from Windows Explorer and use them in Dark default scheme, not sure if it's possible.
Anyway, here you can find few similar color schemes:
Color Schemes - Files - FreeCommander Forum
Dark_Grey_Flat_Default
Very_Dark_Grey_Flat_by_Dreamer
Very_Dark_Grey_Flat_No_Colors_by_Dreamer
