New user with some questions.
Posted: 09.08.2008, 07:07
I have been using Explorer2 for a few years now and just started using Free Commander a few days ago and am really liking it. I have read the help file and the Free Commander home page but have a few problems/questions though.
1. I cannot find a button to create a new tab. There is a button for almost everything but that. This makes no sense to me. Creating tabs is a very common thing in a tabbed file manager. Other than a keyboard short cut you must go into the main menu and create a new tab that way. Am I missing something? Is there a reason for this?
2. What is the Go Up Strip and where is it located?
3. I cannot get Free Commander to remember what folder to open the panes in. I have selected "Start with last used folder" in the settings under "Start Program" but it doesn't work for me. The bottom pane opens in the system folder and the top pane opens to the Portable Free Commander folder. How do I get it to open to last used folders?
Edit:
Another problem. I am using Portable Free Commander. I like to use portable apps because I can set it up once than transfer it to other drives or just put it on my computers simply by copying the folder. This works on all portable apps I use except Free Commander. I set up Free Commander the way I like it on my machine but when I copy it to my thumb drive or another machine all my settings are lost. It launches in default format. Everything was copied over including the settings ini file so why is this happening? Obviously Free Commander is not reading from the customized settings ini. What do I need to do?
Edit:
