Auto selectable views - Add option to sort folders first
Posted: 06.12.2020, 13:25
by stephen147
Hi Marek,
Would it be possible to add a checkbox to the profiles for sorting folders first, then files?
In my example, if I sort on by Name both the folders and files are mixed up.
Re: Auto selectable views - Add option to sort folders first
Posted: 06.12.2020, 14:43
If you mean your settings as described here
https://freecommander.com/forum/viewtop ... 598#p34598
then it is a bug.
We do not need a checkbox. The bug is fixed for the next release.
Posted: 06.12.2020, 16:23
by stephen147
Okay, I found the bug after posting this.
But an option would be useful but no biggie.
Thanks for the fix.
Posted: 06.12.2020, 18:00
Why the option would be useful, if the bug will be fixed, could you explain it?
There is such an option already - "Folders like files", or you mean add this option to Auto views, so it could be used only for some profile?
I moved this topic, I'll move it back to Feature Requests if needed.
Posted: 06.12.2020, 18:16
by stephen147
Just so that each profile could have its own method for doing so.
