XE 2020 build 840 public, Windows 10 Pro 20H2
In particular, C:\Windows\system32\spool. I can browse to system32, but spool doesn't show in the tree nor file / folder list. I can type it into the address bar and go in. I can save / delete files, etc. Just can't browse to it. View hidden files, etc., is enabled.
Any ideas?
Thanks.
Can see folder in tree nor list, but can access it?
Re: Can see folder in tree nor list, but can access it?
I think you are using 32-bit FCXE on 64-bit Windows.
A lot of special folders aren't at the place that Windows shows to you.
http://freecommander.com/en/faq-freecom ... g-32-on-64
https://freecommander.com/en/version-summary/
https://docs.microsoft.com/de-de/window ... dfrom=MSDN
Regards
Ralf
Win10 (64-bit), Intel i7-2600 (3,4 GHz), 8 GB Ram, 500 GB SSD, 2x2000 GB HD, NVIDIA GeForce 545
Ralf
You are absolutely correct... I had forgotten about that. Been a long time since I used a 32-bit app for system functions.
Thanks.
Thanks.
Users browsing this forum: No registered users and 8 guests
