Allow specifying a custom icon for FreeCommander
Posted: 27.12.2020, 15:48
It would be wonderful if the user could specify the program icon for FreeCommander. If this is implemented, I have custom icons for FreeCommander that I will gratefully contribute to the project!
Currently, you can use native Windows functions to change a shortcut's icon to FreeCommander, but that only affects the shortcut icon, and not the program icon used by FreeCommander itself, nor the task switcher, system tray, and other locations.
If examples of other applications that can change their own icons are needed, I can provide.
