replacing diacritic signs
Posted: 18.01.2021, 19:42
Hello
How can I search and replace diacritic signs for a big subfolder structure: The file manager shows me often identical files. One file has an diacritic sign like what´s and the wiew is whats for both. Under DOS with command I have a what?s in notepad view:
D:\00-RockPop\10-Sampler\88-Diverse\cant get you out of my head.mp3
D:\00-RockPop\10-Sampler\88-Diverse\can?t get you out of my head.mp3
It´s not a solution to search for the "?", because it´s getting substitute with the used notepad codepage.
With the file managers quick search:
If I use quick search for
Regards, Michael
FreeCommander XE 2020 Build 834 64-bit donor
DIR > export.txtD:\00-RockPop\10-Sampler\88-Diverse\cant get you out of my head.mp3
I get two entries:can
I get one entrie:cant
Regards, Michael
