841 - Moving large files with Additional Columns in List enabled brings errors
Posted: 27.01.2021, 07:35
Hi.
If you move large files, which take some time and have an additional column, which reads informations from inside the file (in my case it was "Media created"/"Medium erstellt"), the move process will have an error and the file will be copied but not deleted as the delete gets an error.
I tested this with both settings, FC integrated handling and windows handling:
Windows-Handling:
Bring up a windows error that the file cannot be moved, but you have a button to retry. multiple retries needed if it is more than one file
FC Handling:
Error seems to immidiately stop the delete-process, leaving the files that have this error in place and though ending up in a copy rather than a move.
Windows-Handling:
FC Handling:
