841 - Viewer - another stay on top error dialog issue
Posted: 02.02.2021, 21:28
- for viewer use stay on top option
- add plugin uLister.wlx64 to plugins
- F3 to view txt file
= error dialog is shown, but it's behind Viewer window, partly or fully
FC Screenshot_02022021_212508.png (2.64 KiB) Viewed 3830 times
841-1 test
Re: 8411 - Viewer - another stay on top error dialog issue
Posted: 04.02.2021, 21:45
The message is not from FC, I can not control what the plugin do.
Probably it would be correct to switch of "stay on top" if plugin is used.
