841 - exiftool delay
Posted: 04.02.2021, 22:56
- Implemented: Multirename - metadata from exiftool can be used
I tried it with sample images from you, 100 images, Auto preview is ON, with built-in EXIF - date taken I had no delay, but with exiftool - [exift_DateTimeOriginal], I had a delay 50 seconds, whole FC was unusable, frozen for 50 seconds.
8412
Re: 8412 - exiftool delay
Posted: 07.02.2021, 14:30
It is changed in 8413.
Posted: 07.02.2021, 17:18
Thanks, it's great, dialog with option to cancel and I can even use main FC while operation is progress!
Anyway, exiftool is still much slower than "Picture - EXIF", is it normal? Of course, I can use "Picture - EXIF", I'm just curious. I just checked it in XnView, build-in EXIF, multi rename, it's fast there too, instant for 100 images.
Posted: 07.02.2021, 20:58
Yes, exiftool is slower for many changes (exe must be called for each file).
it is an option for many other (not jpg) file types.
Posted: 07.02.2021, 21:10
OK, thanks for the reply. I think I can close this topic.
