844 - Small thumbnail icon is broken
Posted: 14.03.2021, 00:06
Folder thumbnails are OK now, but when loading, small thumbnails with broken transparency is shown first.
To reproduce try to go to folder with empty subfolders and hold Ctrl+R
Result looks like this:
In 8442 small folder icon look like this (no broken transparency):
It's still not perfect, in WE such folders are the same size as others, like this:
EDIT: BTW also icons for some other files have broken transparency, like .url, to reproduce try to hold Ctrl+R:
FC Screenshot_03142021_003047.png (4.57 KiB) Viewed 7230 times
Re: 8443+++ - Small thumbnail icon is broken
Posted: 14.03.2021, 20:13
No such problems on my PC.
Posted: 14.03.2021, 22:44
OK, after testing and holding Ctrl+R few times both icons were changed/fixed, probably the correct icons had to be loaded.
Solved itself.
Anyway, the folder icon for empty items and .. item are still smaller as others, not sure if it's normal, to test just hold Ctrl+R.
