Multi-Rename / Question 2008.06a *solved in beta*
Posted: 22.08.2008, 14:55
by Tankbuster
The multi rename is a great feature. But may be I found a problem, or I need some advice.
FC 2008.06a on XP/SP2
1. I mark all files I would like to be renamed
2. Now I press F2
3. Cursor now flashes in inputfieled FILENAME
4. No I want to change [n] to [n,10,30] but on editing the line I press sometimes the DEL Key, this removes a file from the list instead the char right to the cursor.
So I now the shortcut to remove a file from the list is the DEL key, but could it be not such a global key?
But may be this is just because I'm used to press the DEl key to delete the filed with the focus.
BTW: Before punishing me with "search the forum" - yes I did but did not find something similar.
I do not state this is a error. I just want a info.
Posted: 23.08.2008, 00:24
It's a known bug, already fixed in the latest beta version.
Posted: 23.08.2008, 00:58
by Tankbuster
thx, for the answer.
The Beta section was not part of my search, but from now I will first check this section too.
