845 - "Show in the right panel on the left" status bar issue
Posted: 23.04.2021, 20:48
- use option "Show in the right panel on the left"
- make the main window smaller, as on the screenshot
- in the Status bar setting "Single selection" add items:
[fc_countSel]/[fc_countAll]
[fc_sizeAutoSel]
[fc_dtCre]
Free [fc_discFree]
[fc_name]
- focus any file with long name
= "Free space" is shown in the second row, even if there is enough space in the first row
If the option "Show in the right panel on the left" is disabled, "Free space" is in the first row, same pane size.
FC Screenshot_04232021_204120.png (10.49 KiB) Viewed 9658 times
FC Screenshot_04232021_204142.png (10.02 KiB) Viewed 9658 times
8459
Re: 845 - "Show in the right panel on the left" status bar issue
Posted: 30.05.2021, 16:39
Not fixed in 848, that space at the right is unused.
Posted: 08.06.2021, 22:27
It will be fixed in 849, thanks Marek.
