846 - "Left -> Right" hidden button area issue
Posted: 25.04.2021, 11:44
- disable "Show command line" option
- Status bar - enable "Wrappable" option
- Wuick search/filter/starter - enable option "Show in the right panel on the left"
- make FC window small, +-800x600
- select file in subfolder, so that 2 rows are used for status bar
= "Left -> Right" hidden button area is around the quick filter area, line above and even the whole row below, see the screenshot
This way the hidden button can be clicked by mistake ofter, when clicking the quick filter button.
In the right pane it's correct.
FC left right issue.png (8.99 KiB) Viewed 14751 times
846 donor 64-bit, Windows 10 20H2 64-bit.
Re: 846 - "Left -> Right" hidden button area issue
Posted: 29.04.2021, 00:33
Marek, thanks for the fix, the bottom part is OK now, but the upper line is still broken in 846-1 test.
Posted: 03.05.2021, 22:17
It will be fixed in 847, thanks, Marek.
