853 - Background is black in sync
Posted: 15.09.2021, 17:15
by MrSpock
In 853 64-bit, background is black after compare in Synchronize window. Reverted to 852 and colors returned to normal.
Re: 853 - Background is black in sync
Posted: 15.09.2021, 21:17
I think, more info is needed.
What about default settings?
Posted: 15.09.2021, 22:28
by MrSpock
If I change the color scheme to White_Default, background is fine in Synchronize. I normally use one of Dreamer's color schemes and that seems to be the cause of the problem. I tried a few others to see what would happen and all the ones that I tried cause the problem. This is a new behavior in 853. I will have more time to investigate tomorrow.
852:
853:
Posted: 16.09.2021, 16:28
by MrSpock
The cause is "Synchronize|Options|Use selection colors from main window"
Option Unchecked:
- Unchecked.png (16.68 KiB) Viewed 9004 times
Option Checked:
- Checked.png (15.84 KiB) Viewed 9004 times
