Question about updating FreeCommander (XE)
Posted: 23.09.2021, 20:08
by numbers10
I have not updated my copy of FreeCommander XE for some time. I haven't had to use it much in the past several months. I am at version 840 but I see version 853 is out now.
I have looked in the FAQ and tried searching the forum but I did not find the information I was looking for.
My question is: When updating, can you skip versions? Will you get all the other updates in the latest version?
I have downloaded all the interim versions if I have to install each one sequentially.
Thanks in advance.
Re: Question about updating FreeCommander (XE)
Posted: 23.09.2021, 20:19
by horst.epp
You can always use the latest version which of course includes all updates in between.
If there are special things to do, Marek will say so in the forum announcement.
Posted: 23.09.2021, 20:31
by numbers10
Thank you. That is what I needed to know.
I have been using FreeCommander for almost 11 years (XE Donor about 5 years). I had been using it at work so I would apply updates as they came out. I haven't had to use FreeCommander much this past year so I am behind in applying updates! I didn't recall if updates were cumulative.
Perhaps this should be added to the FAQ.
