859 - Minor - Selected item color issue
Posted: 14.11.2021, 12:41
To reproduce use default settings and click to any file.
With the White Default color scheme dots are used and and looks like this:
fc 859 - Minor - Selected item color issue1.png (2.31 KiB) Viewed 10392 times
Change the color scheme to any dark, e.g. new FreeCommander Dark, then click to any file.
Result is the additional line on the right:
fc 859 - Minor - Selected item color issue2.png (2.48 KiB) Viewed 10392 times
BTW It looks the same also with NC-mode, if the file is selected and focused.
EDIT: It was like this in 830:
fc 859 - Minor - Selected item color issue3.png (2.39 KiB) Viewed 10391 times
FC 859 64-bit donor, Windows 10 21H1 64-bit.
Re: 859 - Minor - Selected item color issue
Posted: 16.11.2021, 22:57
It will be fixed in 860, thanks, Marek.
