Ignore hot item background setting
Posted: 19.11.2021, 11:34
Hello, is it possible to make a setting "hot item" background ignored completely (from Settings -> Select items -> NC-mode (sticky selection) tab)?
It overlaps the stripe-colored background (from Settings -> View -> File/Folder list -> Color/Font tab, Active panel with "Stripe") when hovering.
Example when mouse hovering over FCIcons file (grey line became white):
