Extra Features needed please
Posted: 11.12.2021, 21:19
by Maderez
I am asking for the features, because I have events that happen weekly. Lectures I am giving.
I have many files with dates in their file name. I need to check the weekday corresponding for each date, in order to know how to name them, so I can organize them by subject.
Finding the weekday corresponding to each date (and time of day), so I can rename them all, is a very time consuming task.
- Search: start date + every [n] days (n=7 --> weekly)
exmp:
Search: files [x] created\modified date is 01-01-2021 [x] in increments [7] days [x] repeat for [3] iterations
Result: All files that have a created\modified date of 01-01-2021 ; 08-01-2021 ; 15-01-2021 ; 22-01-2021
*note: 01+7*3 iterations = 22. for 5 iterations it will be the following month.
- Search\Rename: add Weekday to Timestamp (also can resolve the first feature for weekly, rename with weekday than search for the weekday)
exmp search:
Search: files [x] from created\modified date is 01-01-2021 [x] to created\modified date 01-02-2021 [x] On Weekday [Tue]
Result: All files that have a created\modified date in January 2021 that corresponds with Tuesday, (ie. with [cd]\[cm] 05-01-2021, 12-01-2021, 19-01-2021, 26-01-2021)
exmp Rename:
[n]_[cm] [x] Timestamp format: yyyymmdd-hhnnss-ww
Result: file1_20210101-070809-Friday
Thank you for your great product!!
Re: Extra Features needed please
Posted: 10.01.2022, 15:42
How about... just numbering the files and keeping a detailed info about them in Excel?
