With ctrl-F please could the cursor be placed in the File name box for a quicker entry process. Thanks.
I have a feeling it used to do this?
Search - put cursor focus in file name field
Re: Search - put cursor focus in file name field
Which version of FC and OS are you using?
Please upgrade to the latest possible version.
It works good here, tested in 860 32-bit public and 863 64-bit donor, Windows 10 21H1 64-bit.
Works fine here.
Windows 11 Home, Version 26H2 (OS Build 26300.9550)
Running
FreeCommander XE 2022 Build 863 64-bit donor
Windows 10 Pro 21H2
Def not working - is there a setting for this?
Windows 10 Pro 21H2
Works fine for me too (Build 860)
The setting for this is in the search window's own settings under Options and then by checking "open dialog on last used position".
