[863] Interal error when renaming multiple files
Posted: 25.01.2022, 17:11
by Danielsan
863 and 860 have internal errors every time I rename a bulk of files.
I'd like to send the logs but those are too sensitive and I don't see any method to send anonymous logs.
Thanks,
D.
Re: [863] Interal error when renaming multiple files
Posted: 25.01.2022, 21:36
Other possibility is to describe step by step how to reproduce the problem.
Posted: 26.01.2022, 16:29
by Danielsan
These are my steps:
  1. I copy pictures (JPG only) from the Camera SD Card to a new folder on a Windows Server.
  2. I select them and press F2.
  3. Through the dialog window I rename those generically with "name [c]".
  4. Manually through "CTRL+ALT+L" I edit each name file since when an object is oriented to left ends in B and when is right ends A; hence rather than having Pic 1, Pic 2, Pic 3, Pic 4 etc... I have Pic 1A, Pic 1B, Pic 2A, Pic 2B etc...
  5. I click the rename button.
  6. Files are correctly renamed but a windows appears that something wrong happened asking to continue, restart or close the program.
Posted: 26.01.2022, 19:50
Works fine here.
Maybe someone else can check that.
Posted: 26.01.2022, 21:19
Ok, thanks for the report (removed now).
The exception appears only while closing multi rename dialog and quick viewer is open.
The problem is already fixed for the next release.
Posted: 26.01.2022, 21:41
by Danielsan
Nice! Thanks so much! looking forward for the next release!!!
