SFTP - established connection failed
Posted: 16.02.2022, 11:23
HI,
I just purchased donor version as I wanted to use SFTP. Unfortunately I am getting:
"established connection failed because connected host has failed to respond.
Socket Error Code: 10060($274C)
Logout done"
I have tried with blank remote path as well as various folders. I also tried to connect with disabled firewall but it didn't help.
...but I can connect successfully to the same folder via FileZilla or WinSCP. FileZilla can even do quick connect = only use host, port, username and password.
Any ideas?
Is this a bug?
Logout done"
Any ideas?
Is this a bug?
