Cannot see some dropdown menus when using Solarized dark theme
Posted: 18.02.2022, 18:57
Hi there,
I would like to ask whether there is a solution for this: When FC wears FreeCommander_Solarized theme, there is issue with dropdown menu in Imagine plugin https://www.nyam.pe.kr/dev/imagine/. It is partly missing and some other thexts as well (at the bottom of the plugin window).
I really like this nice dark theme. The problem probably is, that this theme affects the menus as well. Any simple workaround for this?
Behaviour of Imagine plugin when set standard theme.
Behaviour of the same plugin whe is loaded Solarized theme (affecting menus):
Thank you!
Thank you!
