Jump list
Posted: 18.02.2022, 20:45
I realized that since some version there is a setting Settings > General > Jump List
release 858:
Implemented: Jump list on taskbar icon
release 864:
Implemented: New option added Settings->General: Activate Jump List
Seems there is no entry in the help file on what does it do and what is it used for. Can someone explain what is it used for? Thx.
Side Question:
The only thing I am missing in free commander is a quick switch from one folder for another with a simple command (CTRL + p) > get a input field and while typing it will show you the visited folders. Similar what fman is doing just that Free Commander is better overall.
Is there a good way to achieve this? Currently I am using quick starter but you need to update the repository too often.
release 858:
release 864:
Side Question:
