Support for ARM?
Posted: 14.03.2022, 04:54
by shapiro88
I just upgraded to a M1 iMac running Parallels. I can't install my purchased version of FC. Is an ARM version in the works? Thanks.
Re: Support for ARM?
Posted: 12.04.2022, 09:31
by psycodad
It is just the installer who do not let you install freecommander on a win arm system. If you use the portable version you can copy the files yourself and it will run without problems (as far as i can see).
