Paths longer than 255 characters
Posted: 06.10.2022, 13:29
Where can I find the feature "Paths longer than 255 characters can be opened, copied, moved and renamed"?
Thanks!
Thanks!
Welcome to the FreeCommander forum!
https://freecommander.eu/
You do not need any registry changes.So after reading the associated article I am still not any the wiser to the answer to the big question: With or without the below registry entry does FC support filenames and/or paths longer than 260 characters?
[HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlFileSystem]
"LongPathsEnabled"=dword:00000001
You do not need search for such feature. Simply you can use paths longer than 255 in FC.Where can I find the feature "Paths longer than 255 characters can be opened, copied, moved and renamed"?
