Address Bar needs style modeled after Windows Explorer or ability to be more configurable
Posted: 07.01.2023, 14:48
[In the wake of this topic https://freecommander.com/forum/viewtopic.php?p=39896]
Below is a presentation of how the address bar of Windows Explorer can look like
And below is the same path but in FreeCommander
As you can see, despite me using a monospaced font, the path is still far from being quickly / easily readable. And repercussion of this is worse navigation to especially short named folders by the means of hovering over a folder within the path and clicking it
And so I propose adding an option to FC of making the Address Bar look alike to its counter part in Windows Explorer
Users should be able to choose which style their prefer using - i.e.: their should be given a choice of configuring these settings:
A] should there be visual pauses and how many of them
B] should pauses be on both sides of the marker
C] what precise sign should be used for the marker
All of the above would be equivalent of the
Tools > Settings > View > Folder Tabs > Tab Management > Mark locked tabs with that character
handy option
