Migration from Public to Donor
Posted: 27.02.2023, 20:51
by RiffRaff
Hello
I'd like to move to Donor from Public, and ensure my current configuration (e.g., layouts, settings, color schemes, etc.) are retained. Can someone please refer me to a link(s) that walks through this process?
Some questions which come to mind (if they're not covered in the links):
> Should the Public (32 bit) version first be uninstalled (after settings backed up, of course) before installing the Donor (64 bit) version?
> Are the install paths identical by default - i.e., would the Donor install just overwrite the Public install?
> Is there any practical reason to install the Donor version and also retain the Public version?
> Should I just overwrite files in ...\AppData\Local\FreeCommanderXE\Settings with versions backed up from the Public version? Are there any files that might create issues and/or are unnecessary and should *not* be overridden (e.g., FreeCommander.hist.ini)?
> Is there anything special I need to do to enable installation on both, my desktop and laptop? How is this controlled?
> Other considerations?
Thank you.
Re: Migration from Public to Donor
Posted: 27.02.2023, 21:09
Don't have to.
No.
No.
You can overrwrite all files.
No. You can use FreeCommander on all your PCs.
Use the function "Tools->Backup all settings" for public version and then "Tools->Restore all settings" for the 64 bit version.
Consider, to use the portable zip version.
Posted: 28.02.2023, 01:41
by RiffRaff
Thank you (again) Marek. Very helpful as always!
I didn't know there was a portable version, and will certainly add this to my utility USB.
Best regards,
- Safron
Posted: 10.03.2023, 14:02
What is worth adding is this:
There can only be one instance of file freecommander.exe running.
And so if for whatever reason a user wants to run two versions at the same time [e.g. to immediately compare them by switching between them with ALT+TAB], then then a user must rename one of its FC EXE files in [or create its copy]
[This topic should be made sticky at the top of this section of forum]
Posted: 10.03.2023, 14:35
by horst.epp
Forez wrote: 10.03.2023, 14:02 What is worth adding is this:
That setting is no problem as you can always add new tabs to the running instance
using /c /t command line switches.
Posted: 11.03.2023, 14:13
horst.epp wrote: 10.03.2023, 14:35 That setting is no problem as you can always add new tabs to the running instance
I think you have misunderstood me, as I was referring to switching between 2 instances / windows of FC thus 2 [e.g.] set of hypothetical bugs affecting display of FC - and not 2 Panels and / or 2 Tabs
Or it is me who has misunderstood your answer
Posted: 11.03.2023, 17:59
Forez wrote: 10.03.2023, 14:02There can only be one instance of file freecommander.exe running.
This is wrong, of course, any number of freecommander.exe can be running, just running 3.
fc exedel.png (10.2 KiB) Viewed 13360 times
Make sure, the option "Allow only one instance" in Settings > General is disabled in each instance, close all instances and re-start again.
Posted: 11.03.2023, 19:16
Dreamer wrote: 11.03.2023, 17:59 [...]
This check out
My mistake
