How do I select files by typing?
Posted: 02.10.2008, 18:38
In the active tab, when I start typing, I expect the selection to update based on what I type. It does for some letters but for others, ie "r", it does not. For example, if I have a tab with the following:
Debug
Documents
Reference
When I type "d", "Debug" is highlighted. When I type "o", I expect "Documents" to be highlighted but the selection stays on "Debug". I see an input box in the lower left corner of the window but some keys don't work in that box. "o" in the above example. Or typing "r" to try and select "Reference" in the above example also does nothing.
Since it seems to work for some subset of characters, I'm sure it's something I've configured wrong.
Any ideas?
Thank you.
Debug
Documents
Reference
Any ideas?
Thank you.
