Synchronize ~ Bugs/Requests
Posted: 17.04.2023, 23:39
by AEN007
Greetings, (Earthlings)
I hope "all is well" ...
or at least "well enough" :shock:
1)
Since ... "forever" ... the Synchronize feature (which I lu💙) has
(gotten) "HungUp" (frozen)
when/while processing a request that ...
a. includes MANY subfolders
b. is (also) searching for "Empty Folders"
This still/repeatedly happens on my ThinkPad P15gen2 & ThinkPad T15pGen3 ~
which are (should be?) more than "powerful enough" ...
Maybe Marek could "take a look" at this issue ...
if/When Marek has time/interest❓
2)
Also, There doesn't seem to be anyway to select or deselect (e.g., with the SpaceBar)
Synchronize-CheckBoxes (e.g., Subfolders, Empty folders ...)
with/through the KeyBoard when/while "tabbing" through the "GUI" with the keyboard ...
3)
I have a(nother) request ... that I'll "save for later" 😼
Re: Synchronize ~ Bugs/Requests
Posted: 19.04.2023, 22:36
Could you write in which step is the UI frozen?
- collecting files
or
- copying files
Posted: 21.04.2023, 04:06
by AEN007
Marek wrote: 19.04.2023, 22:36 Could you write in which step is the UI frozen?
- collecting files
or
- copying files
Greetings Image
When the "Lock-Up" happens ~
which is only if/when the two conditions I specified "exist"~
it always happens during COLLECTING FILES ...
Could be when collecting is in either "Frame" (left or right), however ...
This has been happening for years ... AND YEARS ...
Posted: 25.10.2023, 17:33
by AEN007
- collecting files
or
- copying files
Greetings Image
Any Progress/Updates ... on this ("issue")?
Posted: 25.10.2023, 18:10
by AEN007
AEN007 wrote: 25.10.2023, 17:33
- collecting files
or
- copying files
Greetings Image
Greetings Image
I just downloaded/installed 897x64port-Donor
and tried ... UNSUCCESSFULLY to COMPARE ...
with EmptyFolders & HiddenItems selected :cry:
SAME RESULT ~
NOT RESPONDING / LOCKUP :cry:
NOTE that ... CPU-Usage
is NOT (even) "MAXED-OUT"‼️
Posted: 09.12.2025, 00:27
by AEN007
AEN007 wrote: 25.10.2023, 18:10
- collecting files
or
- copying files
Greetings Image
Greetings Image
SAME RESULT ~
Greetings (again) Image
or at least "well enough" o_0
I just downloaded/installed 939x64port-Donor
SAME RESULT ~
Also, STILL WISH (that) Compare-Selections (e.g., Subfolders, Hidden items, Empty folders etc/etc)
could be toggled with the SPACE-BAR and/or ENTER KEY!
