Zipping large amount of files leads to crash
Posted: 07.10.2008, 13:13
by Ars
When I've tried to zip a folder with total size of ~700 MB with internal packer, FC has been died with error "Access violation at address 0x0000000" after showing "100% done" ; moreover, after closing FC and starting it again, it didn't show its main window until I opened Task Manager and killed a "zombie" FC process...
Posted: 07.10.2008, 16:09
by Fad
I just did a test with a 1.5 gigabyte folder...all went OK here (FC 2008.06a)
Is it failing every time you pack a large folder, to & from different drives and/or partitions ?
Did you check DrWatson (if you allow crash dumps to be made)...
and possibly check your Event Viewer for clues ?
Hopefully someone will have an idea what`s happening. :?
Posted: 08.10.2008, 17:44
by Ars
This is local drive, with a lot of free space.
Seems that it is non-constant issue.
Also, FC dies sometimes when a file is copied by Ctrl-C Ctrl-V from network drive in FC to the desktop.
