Choose Details for Columns could gain from reworking
Posted: 23.07.2023, 18:36
Users can choose which Columns they want to see when using the Detailed View. Here are my ideas and thoughts about being able to configure it in a more convenient way:
#1] Add the X, maximize and minimize system mini icons in the top right corner of this feature
#2] Add an Apply button, so that a user could see effects of changes without a need to close the window. [Hence the need for the [minimize mini icon]
#3] Split the
● FreeCommander
● EXIF - picture properties
● Windows
sections into three separate vertical windows; similar like in case of Define Favorite Toolbars, where we have a separate sub-window entitled Toolbars and below it that nameless one holding shortcuts, each with its own vertical scroll bar
#4] Add a Quick Filter box and make it applicable to all of the three lists at the same time. Such helpful box for filtering had been added in the past in the window of Define Actions Toolbar, which allows for narrowing of a very long list of possible entries to choose from when configuring e.g. the Splitter
#5] The Windows section has on its list three times entry named Status. Are they three different ones or just one and the same? [If they are different then they should be differentiated with a more descriptive names]
#3] Split the
● FreeCommander
● Windows
