[FIXED] New Folder / File window GUI glitches
Posted: 24.07.2023, 12:29
There are few slight issues with this recently updated window for creation of a new folder which appears after pressing of F7 key and its counterpart for file creation [some of which have been already spotted out here https://freecommander.com/forum/viewtop ... 492#p41492]
#1] Initial width
When user clicks the Open to create multiple folders button [the cog icon] back and forth then the width of window slightly changes, which is annoying
#2] Title of window
The bar with title is written in smaller font than other windows. This becomes obvious when user clicks the button / icon, as the alternative window has normal size letters in its title. This is even more annoying because it makes the whole content below shift slightly its vertical position on screen
#3] Horizontal shift
The content below title of window shifts slightly its position also horizontally whenever user presses the cog icon
#4] Width change
Currently the appearance of this window has [almost] fixed size. However after clicking of the button in can be changed and a new width set by user gets carried over to the initial window if user clicks once again this button. Unfortunately it is not remembered after its closure thus after reopening user potentially has to adjust its width once more
#5] The button message
It always says Open to create multiple folders instead of always showing in its balon something like Switch between one and multiple folders creation; or instead of saying Switch back to single folder creation mode when it is seen in its version for multiple folders creation
Re: New Folder / File window GUI glitches
Posted: 22.10.2023, 18:11
All of these issues are fixed now
Thank you Marek
