Can you use File Compare to compare 2 Word documents?
Posted: 04.08.2023, 18:08
by ccamardella
I couldn't find instructions specific enough that I could understand. I know it's me, but, I tried to point to the Word EXE as the program in Settings > Programs> Compare Files, but it is not working. I used parameters "File 1" and "File 2" from the dropdown, then highlighted two word files in the directory. When I click on File > Compare files, I continue to get the same error of "Please define external program: Settings->Programs->Compare files"
Has anyone ever been successful with this? Thanks!
Re: Can you use File Compare to compare 2 Word documents?
Posted: 08.08.2023, 10:28
After activating the menu item "File → Compare files..." or the shortcut "Ctrl+Alt+V" the content of two selected text files is compared
As the help say - with this function you can compare only the text files. DOCX are not the text files.
You can try to convert docx to txt and then compare.
Posted: 15.08.2023, 10:27
by Timon
Use WinMerge to compare word, excel and many other types of files without any convertion
Filter (you can select any file extensions, that you want to compare, I use the following): *.rtf;*.docx;*.docm;*.xlsx;*.xlsm;*.pptx;*.pptm;*.doc;*.xls;*.ppt;*.sxw;*.sxc;*.sxi;*.sxd;*.odt;*.ods;*.odp;*.odg;*.wj2;*.wj3;*.wk3;*.wk4;*.123;*.wri;*.pdf;*.mht;*.eml;*.dll;*.exe;*.dat
Program: C:\Program Files\WinMerge\WinMergeU.exe
Parameters: %FileCompare1% %FileCompare2%
Just now compared 2 doc files and it works fine (of course, just text is displayed, without design, as it is in the Word file)
To compare all other file types I use PSPad
Posted: 20.11.2023, 18:36
by ccamardella
Hi Timon:
I just now see that there was a reply to my thread.
Thank you! It works!
Timon wrote: 15.08.2023, 10:27 Use WinMerge to compare word, excel and many other types of files without any convertion
